Setting the bead - Tire change
As the title says.
Changed the rear tyre today, no problems with the change, but I can't get the bead to set.
Unfortunately I don't have an air compressor, but last time I changed my tyre I got it to set OK with a foot pump.
The bead isn't sealing against the wheel, so the air is just coming straight out.
Any handy hints will be greatly appreciated, don't really feel like taking the tyre off again.
Hawk just for curiosity what brand of tire is it?
Of the 10 times in the last 2 years that I have had to set a bead I've never had one give me any difficulty.
+1 on lifting the tire up
+1 on a ratchet strap
And a ++ 1 on removing the valve core with shop air.
I have used the starter fluid and match method on lawn mower tires - but I have also seen good tires shredded doing that YIKES!!
Thanks for all the help guys.
I used the starter fluid/match method in the end and it worked like a charm.
However as a foot note. I think the curved valve adapter I was using at first may be defective. Had a spare and used that to inflate the tyre fully and everything is OK now.
Once again thanks for all the help, this is such a great forum, but it's the people that make it that way.
