SC21 Engine in SC24 frame
Old 06-01-2013, 02:45 PM
David Van Onselen's Avatar
Default SC21 Engine in SC24 frame
Hi Guys,
I really hope someone here can help me. I recently bought a really ratty SC21 and later found a beautiful SC24. I was told the engines were identical but they aren't. After a lot of struggling I got the 21 engine into the 24 frame, but I now find there are lugs on the frame preventing the two water connectors on the back of the head from fitting. The pulse generator also has four wires and the plug on the sc24 loom only has two. Do I need to swop the generator for a sc24 one? Please guys, can anyone help me out.
Old 06-01-2013, 02:46 PM
Oh, forgot to mention the SC24 engine is blown so I had to use what I had
Old 06-01-2013, 02:51 PM
Sebastionbear1's Avatar
Welcome to the CBR Forum David,
It has been done, in the last couple of weeks there has been discussion about the loom for the 2 wires/4 wires when the engines were changed.
Sprock will remember much better than me on that.
It would be nice to know where you are located as well.
Cheers, SB
Old 06-01-2013, 02:53 PM
I am in Cape Town, South Africa. I am new to the forum and haven't found my way around yet. Sorry if I am asking repeat questions.
Old 06-01-2013, 02:58 PM
Lovely place! Was there in 1996 I think for a citrus conference.
Hopefully Shadow will pop up and say hi! He's East of you in South Africa and one of the most knowledgeable blokes on the forum.
Have you found the manual downloads on the forum for the CBR1000F?
Cheers, SB
Old 06-01-2013, 03:03 PM
No. I found one on the net, but it is for the last models with CBS. Helpful to an extent, but doesn't cover a cross breed 21/24, wonder why...
I am thinking that cutting the water connectors before the bend might clear the frame tabs, but then I have pipes facing the back of the bike. Doubt hanging the radiator on the tailpiece is the answer. Someone must have a better plan
Old 06-01-2013, 03:10 PM
Here are the links from Naga_Thai's signature - he's another bloke with magic fingers on the CBR1000F internals and keeping the bikes running sweet.
WORKSHOP MANUAL - http://tinyurl.com/9hvpymg WORKSHOP HAYNES - http://tinyurl.com/3zbonoa
OWNERS MANUAL - http://tinyurl.com/2e3hhrl
HOW TO -
REGULATOR RECTIFIER - http://tinyurl.com/734engf
CARB SYNC - http://tinyurl.com/6qgfnv & http://tinyurl.com/4o2542
WHEEL BEARING FRONT-
http://tinyurl.com/c23krja
WHEEL BEARING REAR -
http://tinyurl.com/cvqfnrn
PREPARING REPLACEMENT CAM CHAIN - http://tinyurl.com/9lcrcy3
CAM CHAIN & TENSIONER REPLACEMENThttp://tinyurl.com/bjaupex
He has a '90 but the Haynes manual should also cover the '87/88.
Not sure about the pipe - and the radiator on the tail piece would cause too much drag!
I'll see if I can fire the neurones and find that conversation on the 2 vs 4 wires.
Cheers, SB
Old 06-01-2013, 04:04 PM
Here's some information regarding interchangability. Not exactly what you wanted but may help.
https://cbrforum.com/forum/cbr-1000f...estion-146090/
Cheers, SB
Old 06-01-2013, 04:09 PM
Thanks. I'll have a go fitting the SC24 generator so it matches the ECU and the harness. Can't be that hard to do.
Old 06-02-2013, 04:25 AM
Anyone fancy a go at the plumbing problem?
Quick Reply: SC21 Engine in SC24 frame
