remove front axle, why so difficult?
I'm doing maintenance on a friend's '87 1000F, including brakes, fork slide bushings, etc. But I can't get the front axle pulled, it won't even turn left or right. Am I missing something else I need to remove or loosen?
The speedometer gear housing is frozen too, it doesn't move.
I removed the calipers, axle pinch bolts, fender... I jacked up the bike to the point of getting the forks to slide out of the triple trees. Then I slid the left fork off the axle, but the right side (with the axle nut) won't budge. Help?
