Rear rotor clearance?
I just pust fresh pads all the way around on my '93 1KF, but after mounting the rear wheel, the rotor bolt heads just barely bump into the bottom of the caliper, and I can't figure out why.
I did not remove the rotor, and I triple checked both the left and right wheel spacers were in the correct positions.
This happens whether the axle nut is torqued down or not...all suggestions welcomed, as I'm sure it's something super simple and I'm being an idiot.
I'm going to validate that the rotor screws are torqued down properly tonight.
Thanks.
Thanks.
on
Although you said you triple checked them mate I'd qaudrupally check the spacers are seated properly as it sounds like that more than anything. I take it there wasnt any problems before you took the wheel off to do the pads ? I did the rear pads on my 89 yesterday and she went back on just as she was before hand. It would be something minor for sure. Good luck with it.
Sounds like everything is correct. I have .050" clearance between bolt heads and bracket. It's close. The heads protrude slightly above the rotor.
The spacing should be (between the swing-arm),small spacer, bearing (6305UU), spacing collar, bearing (6304UU) and larger spacer.
Could it be that the bearings are incorrect? They are two different part numbers. If the bracket didn't grow, I don't get it.
Are you sure the sliders are working?
It is close, I do remember looking at that and thinking something was wrong but it didn't rub.
I'm going to pull the wheel, and reset both the left and right side spacing collars on the hub, as it seems there should just be a little more stand off distance from the caliper side such that the rotor bolt heads just clear.
If that doesn't cure the ailment, I'll have to resort to posting pictures! :=)
