Rad Leak
Rad Leak
Hi I have an '88 MK1 and the radiator has sprung a leak.
Its not coming from a joint or the core but seeping through
the front face of the end cap. I'm guessing the rad is corroded from
the inside out so I am looking to replace it. Does anyone know
if any other model rad will fit. Either later Cbr or Vfr etc...
John
John
Hey John,
Easiest way is to look at online part numbers on the retailer sites.
VFR is a completely different rad I think.
I'll have a quick look and get back to you.
CBR1000F
19010-MS2-003 RADIATOR 1990 -1996
19010-MM5-003 RADIATOR 1987 1988
I have both models as does Sprock, but I'm a little bit removed from home currently..........
I'd remove the radiator and see if the header tank has just popped a soldered section and see if it can be repaired.
Cheers, SB
CBR1000F
Cheers, SB
