Other model rear calipers
Not sure if this is much help ... but, there's a place here in the UK that I can recommend, who can re-furb your old one .... It'll come back as good as new.....
Brake Caliper Rebuilds
I'm not sure but I thought mk1 and mk2 were un-linked but had different calipers. The mk3 is almost like the mk2 but with linked calipers. If they match the install brackets, yes, the pipe between the outer pistons would have to be married for them to work the best.
I guess the spacers would need to be measured as I am not familiar with them either.
on
Hey:
The rear rotor on mk 1 and mk 2 are the same size, 276mm the only bike I can think of that had used that size rotor with modern single puck CBR1KRR calipers is the VT1100 Shadow. You would have to modify or adapt the mount to work (to mount /weld slide for swingarm attachment) and may need spacers to not bind, but would be the correct size and they can be found at ok prices for example:
99 Honda Shadow VT1100 VT 1100 Rear Brake Caliper & Mount 43F | eBay
Also some older VFRs use the same rear caliper if you can find a nicer one. Good Luck on your search.
Also Mk2 and Mk3 will not interchange unless you change to the mk3 rotor as it is smaller 256mm, but would work if this was changed and was modded to use the dual line caliper. mk1 and mk2 should use a similar caliper just have different mounting brackets and caliper piston sizes older being larger as this is when Honda still wanted extra strong rear overbraking something they have went away from in later modern years. Hence the smaller rotors and less aggressive rear calipers since sporting bikes have gotten smaller and lighter too.
Dub
Dub
