Oil Light ON
Oil Light ON
Ok first my oil bolt came out of the bike so I purchased a 12 / 1.5 standard bolt and a washer from the hardware store. did a complete oil change and now after that the oil light is now on it shut off for a few seconds and then came on full and wont shut off. oil level is good starts great I ran it for a few min too see if it would go off and now I hear a strange noise from the back side of the enigine. would a oil bolt being longer than the original be a problem.
By the way the bike was parked when i noticed the puddle of oil under it
Welcome to the CBR Forum Dennis,
If that's your only problem and that's the only change you made it is likely the culprit. However, are you sure you didn't dislodge the oil pressure sender lead? I think we need to know EXACTLY which bolt was replaced.
Can you show us a photo or locate the offending item on a fiche?
Cheers, SB
Cheers, SB
it is the bolt right under the oil filter there is a second bolt toward the back of the engine that was not touched.
I used synthetic oil 20-50 and a fram ph6017a filter
also a update I put washers on the bolt it is no longer to long the bike starts right away but is making a sweeking noise so i shut it down right away how can i tell if the oil pump is working or if there is flow ?
Does anyone have any idea what the oil tube look like inside the engine I think the bolt I put in may have damaged it I took the oil filter off and stuck something in to the hole and the lower part of the tube is blocked and the top part it open is this normal or is it been damaged byt the long bolt
Its exhaust off job, then sump. Whilst you are at it, replace the balancer shaft rubbers, unless the engine is bugg@r3d.
I took the oil filter off and pushed a pipe into it it was smaller then the hole but it did help I can run the engine and it doesn't make any noise now on a higher idle but the light is still on and it still makes the noise after its been running at the normal idle so my best guess is that I kinked the tube. I am trying not to take it apart but I guess I may not have a Choice. I may try something just a bit smaller that the tube and try pushing it in. The worst thing I think will happen is that it breaks the tube and then I will have to take it apart anyway
Any Thoughts
Any Thoughts
ok I have a noise coming from the top of the motor so it sound like no oil is getting up there.
Is there a oil strainer in the system they may be clogged.
I pulled the oil again and found small parts of leaves in it the best guess would be the got in during the time that the plug was off the bike possible it was dirt sucked in from riding it with out the oil plug.
Just guessing here or the oil I put in had something in it or the funnel I used.
what is the best way to get it out. and is there a strainer part
jerseyjoel
07-25-2008 07:02 PM
my FI light is on and there is a red light i think its the mil light and bike is running great HELP!
cubanjoe
12-27-2007 09:00 AM
