oil change issue
^That's the one I use. I use a long extension and a breaker bar. Wiggle the filter wrench between the lower fairing opening up front to get it on the filter and then slide the extension in. I do it from the right side of the bike so I turn the handle bars to the right to give me the room I need to get the extension in.
The filter will drop out the bottom. No need to pull any plastic for oil change.
Last edited by TimBucTwo; 10-23-2014 at 03:56 PM. Reason: Love needs room to grow, like a rose, or a tumor.
Motion Pro makes something that they claim will work on any spin-type oil filter. You attach the strap to your ratchet extension, wrap it around the filter and go to it.
Motion Pro Oil Filter Strap Wrench
Here's another idea below. The metal body won't strip out as easily as those ones with the plastic nut on the end. It squeezes tighter on the filter the harder you turn your ratchet.
