oil change issue
oil change issue
Well its time for my new (to me) bike to have the oil changed. I've got a new filter, new oil and time to get it done. The problem is that the filter is on so tight that IT WON'T BUDGE NO MATTER HOW MUCH FORCE I APPLY. I'm afraid if I pull to hard I'm going to strip the bolt head on the end of the filter. I though these things were supposed to only be hand tight plus a quarter turn. It doesn't look like there is enough room for me to use a strap wrench either.
Any ideas?
Any ideas?
I've always found that the first oil change on any new vehicle for me was a pain because the filter was on tight as a lug nut. My theory is that they don't take the time at the factory to put a film of oil on the gasket before screwing it on and it sort of welds itself to the engine.
My solution is usually to hammer a screwdriver into the filter body and use it like a T-handle. Once you make that hole you have to keep going because then there's no changing your mind and deciding to drive/ride it to the dealer and have them change it.
