No drive
Old 08-05-2012, 09:15 AM
PILGRIMSUPPORTER's Avatar
Default No drive
So got bike back together after painting etc. start up no problems but no drive to back wheel. Doesnt feel like its going into gear correctly, was fine before I replaced with anodised bolts. The gear change cover did come loose so maybe something came loose or displaced would appreciate some advice
Old 08-05-2012, 01:35 PM
Sebastionbear1's Avatar
How long has it been sitting? Clutch plates may have stuck together.
Did you check that the clutch is actually engaging/disengaging when you pull the lever?
Did you change all the external engine bolts with anodised? i.e the clutch slave houseing as well?
Were all the bolts the same length as the ones they replaced?
Did you do an oil change at the same time and perhaps overfill the engine with oil?
Have to narrow it down Pilgrim.
Cheers, SB
Old 08-05-2012, 06:48 PM
Sprock's Avatar
Well if the sprocket cover has come outwards the clutch rod is not
actuating the the clutch
All those bolts are different lengths and some have specific collars
If the sprocket cover was off for any length of time the clutch slave
cylinder relaxes out too - all factors to consider
Old 08-09-2012, 09:19 AM
Default Only feel bit of a plonker
Well found my problem of no drive. Only chance I have had lately to get in mancave. Took off sprocket cover turned back wheel, front sprocket not turning but chain going round. When I fed chain though to front sprocket there is a collar in front of front sprocket which i put chain. This held chain on but no drive. Ten minutes later chain on correctly and took up road boy dont it go. Have Yam R1 shortened Yoshi silencer on right side and blocked off left side, no jet changes and standard air box and stick coils, well happy
Old 08-09-2012, 11:58 AM
TimBucTwo's Avatar
^funny but not funny all at the same time.
Happy endings are the best.
Old 08-09-2012, 03:19 PM
pmcg's Avatar
Looks good. Give us some more pics/details about removing the from cowl. What bars are you running? New cables? What did you do with the oils cooler?
Old 08-09-2012, 03:40 PM
As Tim (kinda) says Pilgrim, a happy ending is a good ending. And thanks for posting your D'oh moment. It happens to all of us at some time or other.
Cheers, SB
kilgoretrout
The Hurricane Saloon
146
06-09-2012 02:07 AM
07white600rr
05-10-2010 07:20 PM
05-13-2009 11:12 AM
woo545
07-13-2008 12:36 PM
telgren
04-23-2007 04:14 AM
Quick Reply: No drive
