Newb Needs Guidance
#31
#32
It can be a real trial, Charles, especially if it's the first time in years that it's been moved.
Patience and perseverance will be my best advice.
IT WILL GO BACK IN
As for the fuel pump, sorry, mine's a mk2, doesn't have a fuel pump, but at a guess I'd say jumper cables.
(Mk2 bikes have a vacuum unit on the carbs which only opens when the engine is cranked. Can be a real pain to start if the bike has stood for a while) Not sure if the Mk1 has the same system, but if you crank it then you'll KNOW the fuel's getting in.
Good luck with it.
IT WILL GO BACK IN
Good luck with it.
#33
OK, had to go back all the way to post 1 and try and get a handle on this.
The Mk1 fuel pump is not like the fuel pump in my old Mk1 Jag.
In the Mk1 Jag , you could hear the fuel pump start up and start sending fuel ($1 coins) through to the carbs as soon as you switched on the ignition.
With the Mk1 Hurricane, the fuel pump does not play any role until you hit the starter button.
So; download the Haynes Manual available through this site, it has some test procedures for checking if your fuel pump is still alive.
Last edited by kiwi TK; 01-25-2015 at 06:14 AM. Reason: I had a rush of blood to the head; I thought I had spelt fuel incorretly. Apparentley not.
#35
No joy. I can feel the fuel pump pumping, but I'm not getting any gas thru it. The petcock flowed water thru itself when I was cleaning the tank. Out of time to work on it today...the job beckons. I shot some starting fluid in the intake on the side where the air filter is, but I'm thinking that is just too far for it to travel.
#37
I'm really trying to keep it as close to stock as I can because I am fixing it up to resell. The only things that aren't stock are the Lockhart windscreen and the what I believe are Cobra cans. The cans have no markings on them but the straps say Cobra. Let's say I do remove the pump, what sizes are the fuel hoses I would need to use?
#38
#39
My top tip for refitting the carbs, is to take a small section of 1 x 2 and use that to push against the carbs. As Hamlin advised, start with No4 and then No1 and wiggle them on working from side to side.
Also plenty of lube will help
The reason I mention this is you may have to try a couple of times getting the tubes underneath properly aligned.
Also make sure you've re-attached the throttle cables, or you'll be getting even more practice. These are all mistakes I have made
