Newb Needs Guidance
Maybe I should have phrased it better :- My favourite method is to lever them off using a piece of wood to protect the cam-cover and they'll pop right off.
Sorry my bad
Don't give up, they will come off. All of us that have been there, certainly understand your frustration. You gotta remember, those boots have had years and years of heating up and sticking to the intakes. It takes some major persuasion to get them off the 1st time.
As others have said, heat helps. Another thing is if you have a rubber mallet, gingerly tapping on the carbs with that can help. But the heat and prying is the best helper you will have.
I find the best method of removing the carbs is; loosen the air box to carb clamps, loosen the air box bolts and push the air box back. Then loosen the carb to engine clamps and with some kind of leverage tool (ie, small length of broom handle) inserted in carb #4, rotate the carbs upward. They should release easily.
Once again, don't try to remove them backwards but instead rotate them upwards and they pop out.
There are four of them you'll have to locate and slacken off on the engine side.
No, you don't want to end up trying to organize 4 intake boots back onto the head. Getting them all back into the correct alignment will do your head in. There is a wee notch in the bottom of the boots on the carb side that the clamps use to seat up against.
If you don't get them all lined up nicely you will still be swearing in a weeks time.
Is this going the be one of those "up to your *** in alligators when all I was really trying to do was drain the swamp" stories ??
