New Fork Springs
Old 07-07-2010, 10:09 AM
Bassman's Avatar
Default New Fork Springs
Just wanted to let you guys know that I finally got my new Progresive Suspension spings installed. My buddie Steve came over to help Sat. I finally remembered how to compress the springs during instalation. I put a screw driver shank between the coils (two are better) and pushed down while Steve put the spacer on the stack. I had cut a slot in the spacer for the damper rod to pass through.
The spring rate is 0.71/1.16 kg/mm or 40/65 lbs/inch. I have about 410ml of Mobil 1 Synthetic ATF in each leg. The viscosity falls in the middle of the 10w fork oils available.
Progressive recommended 1.5 inc spacers vs. 2 in. stock spacer. The PS spings are 0.5 in. longer than stock. I made my spacers 1.75 in.
Total sag in front is now 28mm, rear 25mm. That's with me @ 260lbs and 4.5 gal. of gas in the tank.
I can feel the difference in ride height and the front does a better job soaking up sharp edged bumps. The compression damping is a little more than I'd like so I will probably be playing around this summer with different oils and levels. I don't have the ambition to instal the Race Tech valves even though I've done it before.
Old 07-07-2010, 11:34 AM
Shadow's Avatar
Great info, Bassman !
I think a sticky or placement in the how-to's may be in order.............
Old 07-07-2010, 08:44 PM
hawkwind's Avatar
Compressing the springs was a question I have asked in the past, now you mention 2 screwdrivers it seems pretty obvious
I've got some brand new fork tubes waiting to go on, but I can't bring myself to whip the forks off again while the weather is holding, but I'll give your method a try once I get around to it.
jackojeff
03-09-2013 01:41 PM
underground-mpyre
F2 Tech
42
09-19-2011 01:50 PM
bigape
05-24-2008 07:34 AM
land_warrior.rus
07-11-2007 03:09 AM
davethepom
11-15-2006 01:32 PM
Quick Reply: New Fork Springs
