New CBR build need help
Old 10-06-2012, 01:04 PM
melvinew2's Avatar
Default New CBR build need help
This is my new 88 cbr 1000f i was told it had a 94 motor on it. I got it not running because the wires where cut ever where. I just got the wire worked out fix about 20 brakes. I really need pic of they way the stock wires are ran on the bike? Also any idea on what i can do about the coolant hose? Can i use auto universal hose? [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Also what is this plate is it part of a evap system ?
[IMG][/IMG]
Old 10-06-2012, 04:06 PM
Sebastionbear1's Avatar
G'Day Melvin,
Wow, you like a challenge - and good on you for that.
Firstly, if you haven't already go to the workshop manual link and download the manual for your bike (or buy a hard copy) https://cbrforum.com/forum/workshop-...anuals-101309/
Often the manual will have cable runs illustrated in them, or at least from the dismantling sections you can see where the cables are placed.
For the radiator hose, personally, I'd go Honda replacement, because if you're intending to replace all the fairings, those little buggers become VERY hard to get to. And I'd bite the bullet and replace all of them.
A couple of other things, as the carby bank doesn't look like it's a mild V shape, I'd say the PO is correct and it is a later motor which brings up another point regarding a small water hose from the water pump to the top of the engine block above the water pump. Naga Thai was researching the differences in this and I'll find the link and post it for you.
Next, check all the engine frame bolts. In the last photo you posted, centre bottom shows an empty bolt point and what appears to be an offset engine mounting point. You may need to check if the frame is straight if this does not line up.
Anyway, good luck with the build and post questions as they arise.
Cheers, SB
Old 10-06-2012, 04:24 PM
melvinew2's Avatar
Yea it ain't as bad as it looks. I have all ready had it running for about 10 sec. I have had many bikes but most of the time i keep with the old cb750 sohc. I had a friend that want to trade me the the bike for a 88 camaro i had siting in my yard for 3 years that need a motor so i said sure i like bikes more any ways. i have some more pic i will post of the bike form the day i got it! yea i saw that motor mount bolt missing my self the holes line up look to me the Po lost the bolt !
Old 10-06-2012, 04:36 PM
McBreezyF4i's Avatar
Wow that wiring looks like a nigtmare
Old 10-06-2012, 06:17 PM
hawkwind's Avatar
There should be a coolant hose there for the cylinder head, I wouldn't be too keen to run the engine without that connected.
There should be another hose opening on the other side of the cylinder head.
As Seb says, have a look at the workshop manual, it'll give you an idea of what goes where and if anything is missing.
P.S.If that is indeed a '94 engine, the carbs don't look like '94's. Check the engine number for the date of manufacture
xxxxxxxxxxxxxxxx
Old 10-06-2012, 06:45 PM
melvinew2's Avatar
Here are more pic and a video. I would right back faster but ever thing i wright has to be approved for some reason. Kind of a pain! [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
AND HERE IS A VIDEO !!!! 1988 cbr 1000f hurricane first start - YouTube
Old 10-06-2012, 08:24 PM
melvinew2's Avatar
just looked up the motor vin it is sc24e2301377 !
Old 10-06-2012, 11:29 PM
slowpoke's Avatar
The air-cooled alternator in the first picture shows that the engine is pre-89.
Old 10-07-2012, 12:17 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
But engine Vin SC24E indicates post '90???
Old 10-07-2012, 01:00 AM
Shadow's Avatar
ever thing i write has to be approved for some reason. Kind of a pain! [IMG]
It's all part of the system to keep spammers out.
You're good to go now..........................
Quick Reply: New CBR build need help
