New 1000FK (L owner South Wales UK. My project.
#102
Yeah straight forward, the only downside was the length of cables coming from the controller meant that on full LH lock the connection plugs ideally want to pass over the top of the frame under the edge of the tank. If they were 30mm longer at the connections then it would be better.
I used superglue to stick the grips on and managed to drop some on to the fairing!!!!!! My own fault. I removed the cloth too soon and it ran down the cable before it dropped.
Straight from the battery and they don't wanna run unless the bike is running although when you shut the bike down they will stay on until the battery gets to a set voltage then switch off.
#103
#104
#110
My bike has been on eBay for the last 28 days and I've had 2 x interested parties. One of which called in the p!ssing rain an asked could he take the bike out for a try (in the rain with no cash and no assurance of insurance cover) so I politely refused but offered to take him pillion. That had the desired effect of making him part with a deposit. So all being well it'll be gone in the next couple of weeks on the proviso that I remove the water pump and refit a new seal to stop the minor oil loss from under the pump as he spotted the rainbow on the pavement.
So today I did just that and when the LH fairing came off I noticed plenty of rusty coloured water down the side of the engine block and a slight weep noticed at the base of the coolant elbow once up to temperature. Turns out some ham fisted buffoon has cracked the coolant elbow by over tightening!!! One used part on order from eBay to hopefully be fitted next week before collection.
Stripped,
back together,
a little leak,
Stripped,
back together,
a little leak,
