on
I hope you weren't going fast. Chains coming off is a frightening possibility. Be thankful you still have your left leg in tact. If that cover is all that's damaged think yourself lucky.
Yea I was under heavy acceleration, close to 90 mph. I consider myself lucky, and have the intentions of going after the chain manufacturer for the damages. It was a new chain put on 2 Weeks ago.
No I did not replace the sprocket, however u will need to now because the chain broke of a tooth. I went with a wps chain, which I will not be buying again. And I did install the master link the correct direction. Riotous yall recommend going with OEM sprocket, or a aftermarket size.
