My starting problem
My starting problem
Here's my starting problem:
http://www.youtube.com/watch?v=BXsp0Y_lpI4
Does this seem to be consistent with the alt damper issue? It doesn't quite sound the same. I've got a good used starter clutch on order just in case.
Can the starter be tested at an auto parts store?
Thanks
Thanks
on
imo
Yep sounds like the "classic" signs of bad starter clutch alternator damper unit
Compare against this
http://www.stu.co.nz/cbr1000fix/
Does it "bump" start easily ?
Then it's not the starter damper. May be the starter clutch.
Check your choke cable - make sure it's working correctly - only the top 20% of the choke actually changes the choking.
With those sounds I would expect the bike to start, IF the battery is up to full charge........
Are you getting enough spark ?
What about your fuel pump................?
On the other hand, if it will not bump (push) start, I would check under the tank to see if the enrichners are in the full up position when the **** is turned. The enrichment slide needs to be slid right. Try to help it with a screwdriver while twisting the ****. These bikes will not start if they are not enriched. Due to the EPA, when these bikes were build they were made to run lean. They will not start without enrichment.
I pulled the carbs and they desperately needed to be cleaned out. I think that may be why it didn't start with a bump start. I'm also going to change the spark plugs. I've got a starter clutch on the way so if I can at least get it to start with a bump start then I'll have gotten somewhere with it.
I have not had that problem but it sounds the same as what has been posted before. It seems that all the power is going into cranking and it is not cranking fast enough to start.
So what are you jumping it off of, cybertrip? Is it a known good battery? How do your jumper cables look? Battery terminals good? Just a few thoughts.
Also, throttle won't do anything on cold startup other than keep the bike from starting. It allows too much air in, and basically just negates the choke and then some. Full choke/no throttle to start 'em when they're cold.
Cleaning carbs is a probably a good idea, tho.
Yeah, that's what's strange to me, too. It doesn't sound like a slip at all. It's almost like it's just not getting enough power. (just like when you're battery is about beat)
I'm almost wondering if there is a problem with the starter motor.
Tried her again this evening and there is definitely fuel going in to the cylinders. One of the cylinders keeps lighting off. It's just not rotating fast enough to start it completely. I'm a newb at push starting so I can get it to start for just a moment before it dies.
The guy I purchased it from used a halogen light as a block heater and said that usually helped with getting her started. So, it seems that the cylinders have to be warm to start, maybe thinning the oil viscosity which reduces friction allowing the cylinders to move easier? This makes it sound like the starter is the problem. We'll see what happens when I replace the starter clutch. I wish I had a way to test the starter itself to verify if it is the problem. Will these work on car starter testers?
