My Hurricane will no idle right
I start the bike up and it purrs like and kitten for 3 minutes then it just goes erratic, unable to hold steady revs, seems slightly starved then races ??
I'm in the UK but this CBR spec is for the US and i've never seen so many pipes come from the carbs to crappy emissions thingy me bobs before? .
I've done a carb strip and clean, new plugs, freshly charged battery, checked all terminals, new filter ???? I'm baffled.
advice required thanks
All the emission hoses can give you vacuum leak problems, which again makes for a lean out condition. On my US/California spec '94, the system was all still in place. I did read where other owners had removed the PAIR/PARE? system and plugged the ports on the front of the head. Maybe see the search section of the forum. I don't own the bike or manual any longer so research is limited to my feeble memory.
So check the tank vent and inspect hose connections thoroughly for starters.
davecrx
10-12-2015 05:23 AM
