Mirrors again!!!!!!!!!
Old 08-02-2010, 05:57 PM
shakey's Avatar
Default Mirrors again!!!!!!!!!
Evenin all ..... Just a quick question!
A few weeks ago I was on the way back from Yorkshire when my R/H mirror (which was slightly damaged) parted company with the bike on the motorway at a silly speed! ( Yes, it was previously damaged!) ...... So I need a replacement!
Question is .... I've found one from a CBR600F - J (mine is a 1000F-J) .... Is the mirror the same? It looks the same from the piccys on EBay????
Fanks
Old 08-05-2010, 12:16 AM
hawkwind's Avatar
Not sure if they're the same Shakey, check out the part numbers, if they match up they'll be the same
Mind you, if you ride fast enough, what's behind you is receding and don't matter, 'cos it's moving away from you. Just ride fast enough to loose your other mirror and you should be O.K.
Old 08-05-2010, 12:22 AM
Shadow's Avatar
I'd buy a set for the Mk 3 - longer arms and easier to see, and will fit (and prob cheaper)
e-Bay had them in both US and UK......
And I believe the 600 and 1000 mirrors are the same.
You can always check by looking up the part numbers on
www.mrcycles.com
Old 08-05-2010, 01:41 PM
shakey's Avatar
Thanks for the info lads .... I had a look at the MrCycles link ... the ONLY part numbers missing were for the R/H mirror! Just my luck!
I'm not really bothered about originality, and would definately like the idea of mirrors that were a bit wider than the stock ones! ....
Will the later model mirrors definately fit my F-J????
Thanks
Old 08-05-2010, 10:02 PM
kilgoretrout's Avatar
Administrator - Retired
I've never seen 2 part numbers that match up on that dam site...lol. (even with parts I know will cross)
I tried to look it up for you in other places, shakey, but I couldn't find an answer for certain on the 600-1000 swap. I want to say they do, but I've never done it.
Phantez
07-06-2011 12:07 AM
WorcHonda
F4i - Wanted
08-19-2010 05:54 AM
espelade
08-08-2010 01:49 AM
Napalm1000
04-01-2008 04:14 PM
90f1rider
02-22-2007 09:04 PM
Quick Reply: Mirrors again!!!!!!!!!
