Main Jet Sizes ?
Main Jet Sizes ?
Just removed the carbs from my CBR1000F-R to have them sonically cleaned. Thought I would have a quick look to check the main jet size because I'm having fueling issues. My Haynes manual states 122 but they are all 102, can anyone confirm the correct size please? The inlet rubbers have a metal plate in them
Is this correct? The bike was a Japanese import when it was 5 years old.
Suggestions please brothers
Input your details on this site and you can order what jets you like. I did look at them as I was gonna order a set but didn't bother in the end.
Jet kit Calculator for Carburetors
Jet kits for yours here.
Honda Jet Kits :: Honda 1000 cc Jet Kits :: Honda CBR1000F Hurricane 1993-1996 - Jet kits for Carburetors
I bought it fitted with a Laser 4-1 exhaust & when I removed the air filter the one end of the filter was blanked off with gaffer tape. I did a service & put new filter in & it wouldn't pull past 4000rpm. Replaced old filter & it was back to normal, not perfect but better. I'm going to replace the 4-1 with Black Widow stainless headers & original mufflers but thought I'd have the carbs cleaned so I knew everything was spot on. It must be a Japan emissions thing I guess - small jets & restricted inlets.
It might be too fast when I get it running right?
Thanks for your replies, all the stickers on the bike are in Japanese and there's a Japanese bike shop sticker on the rocker cover + tail fairing. Is Japan a low power version? Do you think the cams might be different from a full power version? Is there a list somewhere of Country specific models and their differences please?
I doubt very much that a California model would find it's way to Wales, so I think that rules out emissions control.
I'm not sure if Japan has power restrictions, but it wouldn't surprise me if they did, there were also parts of Europe where restrictions apply.
I think if you're reverting back to stock exhaust, then I would fit standard sized jets and remove what appear to be restrictor plates.
Just make sure you hold on tight when you test ride
