Installing LED's on the saddlebags
Old 03-16-2010, 08:32 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Default Installing LED's on the saddlebags
You need to take out the 2 screws (photo 1) and take off the red cover. next you need to drill a hole to run the wire inside (photo 2). stick the LED's (white) where the cover went (photo 3) Look at the red cover and see where the groove is so you know where to place the LED's. install the cover and connect to 12 volt source (running lites).
Ok I do need a 12v all weather connector so I can run the power outside the bag. So I can connect the power (12v) when the bags are on and disconnect the power (12v) when I want to take them off. Any suggestions???
Old 03-17-2010, 09:37 AM
tobiahr's Avatar
you could order new weatherpack connectors from http://www.rjminjectiontech.com/?p=12 for 2$ per set or goto just about any salvage yard in the states and cut one off a gm vehicle made after 1998 for 50 cents and splice it in. they are kind bulky but are pretty much guaranteed to be weatherproof.
Old 03-17-2010, 10:11 AM
Shadow's Avatar
I'd be inclined to refit your underseat mudguard to keep the muck out............
For connectors, I would use a quick release, like a philips connector from a speaker, to a waterproof connector with a cover, then to the battery. Put it under the seat. You then won't have wires trailing from the boxes when you remove them.
Old 03-17-2010, 01:32 PM
Sprock's Avatar
Ebay Version same as tobiahr
Old 03-17-2010, 02:28 PM
I found these on ebay Link mount thru the bag.
Old 03-17-2010, 03:00 PM
Sprock's Avatar
They look good Indy .....coat of clear for that HK chrome to keep 'em shiney ??
cbrchaz
04-25-2011 03:29 AM
gtjimm
07-17-2009 09:13 AM
Alarm
06-07-2009 07:18 AM
TheFlatulater
Riding Gear
09-11-2008 02:55 AM
Todd84
04-15-2008 10:15 AM
Quick Reply: Installing LED's on the saddlebags
