ignition issue
Old 07-19-2010, 04:19 PM
NE1000F's Avatar
Default ignition issue
When I turn the key on today, I got the normal response, the dash lights lit up, but when I hit the starter button, the lights shut off and I heard some type of pop under the seat. I switched the ignition off and on again and nothing. So I checked all of the fuses and all were ok. I thought my starter may be bad, but I should still be getting juice when I turn the ignition switch on, right? I'm not sure where to go from here.
Any Ideas?
Old 07-19-2010, 10:14 PM
cbr900racer77's Avatar
Did you check the main fuse at the starter solenoid? If you don't have lights or anything with key on, you've probably popped it.
Old 07-19-2010, 10:35 PM
kilgoretrout's Avatar
Administrator - Retired
+1. Sounds like you popped the main. It's a 30A fuse... on it's own... next to the starter relay.
Old 07-20-2010, 06:55 AM
NE1000F's Avatar
Yup checked it and it's fine. I waited a little while and turned the key in the on position and still nothing, but I left the key in the on position and all of a sudden I saw the dash lights light up. I'm thinking I have an exposed wire somewhere, but on the other hand When I'm riding it's fine I never loose "juice".
I plugged my battery into a charger and it was below 80%. It started fine then rode to work. Got home and just plugged it to the tender again and it showed it was below 80% again. So would/could it be just low battery?
If it's not one thing it's another.
Old 07-20-2010, 08:59 AM
cbroar's Avatar
I had a similiar problem and it was my ignition barrell. Left the bike for a few months and when i turned the key i got nothing. Wiggled the key a little and all the lights lit up. Soaked it in wd40 and it was fine until i sold it.
Charging problem could be a bad regulator rectifier. Not too expensive to replace and very easy job, its bolted to the left side of the sub frame.
Old 07-20-2010, 10:51 PM
NE1000F's Avatar
Fixed the issue. Tightened the battery conections. The positive screw was loose. WOW I love easy fixes.
jacksla3
03-13-2014 05:02 AM
streetfighterF4
11-12-2012 03:34 PM
lilpaco
09-17-2011 11:08 AM
Sagery
03-16-2011 02:56 PM
89cane
04-14-2009 03:17 PM
Quick Reply: ignition issue
