I need some help from the pros!!!!
Old 03-27-2013, 06:25 PM
chaser1's Avatar
New Member
Default I need some help from the pros!!!!
i bought a 1988 honda cbr 1000f hurricane but i have been having issues? its really hard to start it turns over and over and finally fires but sputters like its flooded? it has a non stock universal fuel pump? my dad and i rebuilt the carb and it helped but not all the way it idles hot but not cold. so i replaced the spark plugs but while doing so i noticed that plugs on cylinders 2 and 4 were soaked but 1 and 3 were not dry but u can tell they were firing. could it be a bad ignition coil not firing 2 and 4. i have also noticed that it sounds way differant than most of the other hurricanes.
Old 03-27-2013, 06:52 PM
Sebastionbear1's Avatar
Firstly welcome to the CBR Forum Chaser,
Now to your problem, CBR1000Fs love a really full battery, so is it charged fully? You don't actually need the fuel pump, the Mark 1s ('87/'88) can be plumbed in with the fuel line going directly to the carbs from the tank - gravity fed. And after fettling the carbs did you balance them?
That's where I'd start, then look at the coils. Make sure all the connections are good and the resistance is correct for each coil.
Let us know how you go.
Cheers, SB
Old 03-27-2013, 08:43 PM
Sprock's Avatar
Your 1st left coil fires 1 and 4
the right coil fires 2 and 3.
I'd start there
Old 03-28-2013, 04:00 AM
Naga_Thai's Avatar
I'd start there
As Sprock stated - make sure you have correct HT connections...
Old 03-29-2013, 06:10 AM
DragonCBR's Avatar
You guys are right , sounds like bad coiles or bad spark plug wires...
Old 03-29-2013, 04:15 PM
chaser1's Avatar
New Member
Thanks guys turns out to be my carb completely un balanced two cylinders getting little gas. Other just flooding
Old 03-30-2013, 05:28 AM
outlawfox13's Avatar
Welcome, and lets see that bad boy!!!
If your float heights are not set corectly or float needle not closing properly can cause the little to no fuel issue as well(ask me how I know)
Old 03-30-2013, 09:17 AM
How do you know??
Cheers, SB
Old 03-31-2013, 01:37 PM
slowpoke's Avatar
I was a scientist for years. It is like being a detective. So here is the problem: Cylinders 1 and 3 are firing, but 2 and 4 are not. Cylinders 1 and 4 are on the same coil, and cylinders 2 and 3 are on the same coil. So we can surmise that both coils work.
If the problem really is ignition related, then there has to be a problem with wires 2 and 4. The first thing I would check is to see if those two wires are going to the wrong cylinders. If they are correct, I would check the resistance of the two wires. There are little resistors in the sparkplug end of the wires that can go bad and the wire won't work at all.
Assuming the piston and valves are sealing, the problem then has to be with carburetors 2 and 4. If the spark plugs are wet, the piston/needles in those two carbs could be stuck in the up position, flooding those two cylinders.
volcom440
12-01-2011 04:36 PM
kaylor99
08-11-2011 08:12 AM
FlyF4i
05-13-2010 09:57 PM
CBRfenatic93
04-13-2010 01:42 PM
Ericy05
07-03-2008 08:44 AM
Quick Reply: I need some help from the pros!!!!
