Hot water gurgling noises
OK, like I don't have enough problems with my battery charging, slow puncture, lazy centre stand...
Arrived at work this morning, switched off the ignition, could hear the noise of hot water gurgling and rushing, and saw water dripping out under the middle of the bike. It stopped after a few teaspoonfuls had dripped out. I started the engine, the fan cut in (hot engine due to heavy traffic), waited 30 seconds but no more water came out.
I don't think the leak is from the water pump.
Could it be something silly like the rubber cap is not secure on the coolant overflow bottle? Or is this just some sort of overflow mechanism (which I've never noticed before)?
Thanks again folks.
Thanks again folks.
There's a 3-way Y shaped plastic hose connector up near the radiator.
If it cracks you'll get a small amount of water due to pressure- if it goes completely you'll be stuck, so have a good look at what's going on.
It may of course be a cracked hose or a loose clamp.....
Wemoto may be a good option for a spare. Some of us have had stainless ones made by one of our members. Ask Sprock about it.
The gurgling sounds like she was boiling so as a minimum I'd check the radiator level.......
check your exspansion tank as well, I had an issue with my mk1, it would drip out by the stand, when I checked it out the overflow pipe for the tank was to long and went almost to the bottom of the tank so when she got warm the water was pushing out the overflow, took a bit off the pipe and it hasn't happened again
Where is this pipe connected? Do you mean the breather or the syphon (as in service manual)? I don't see a pipe that goes into the tank itself.
However I noticed my centre stand has become quite stiff lately and there's a rubber tube hanging down by it. Never saw that before. Will have a look.
f4izombie
07-04-2011 11:08 PM
cb2cbr
03-08-2007 11:20 AM
