To hot to start?
Old 01-31-2016, 10:11 AM
Nodrog1966's Avatar
Default To hot to start?
CBR1000FL 1990. After running until fans kick in I cannot get the bike restarted. Anyone has an idea?
Plenty of fuel and plugs sparking although slight back or misfire noted when idling.
Old 02-01-2016, 08:04 AM
TimBucTwo's Avatar
If I had to bet, I say the battery may not be up to the job of cranking a hot engine. And that may be due to the R/R getting old and not putting a good charge on it.
The blackish plugs and misfire, I would bet are from a week spark.
If it were me, I'd replace the R/R and do the stick coil mod. You should do those two mods anyway to burn the modern fuel. You need a hot spark for that. those two things right there are the best bang for the buck to update your bikes ignition and charging system.
Stick coil mod LINK
R/R LINK <--this one is plug and play, I have this one and it charges at idle
rather than the factory one that starts to charge around 2,500 rpm. It your R/R is the factory one and the fan is running, the fan may be pulling your battery down. This R/R will help.
Old 02-04-2016, 12:51 PM
bullroarer's Avatar
Exhaust or inlet valves could be too close, ie gets hot even closer still, causing lack of compression......Possible cause.
Old 02-04-2016, 02:54 PM
BrianCWhalen's Avatar
What is your idle mixture screw setting? If you're lean on your idle mix setting (2.75 turns from lightly seated is OEM factory setting), it could be the cause. I would check one of the outer (#1 or #4) and see what it is. Might experiment with 3turns or even 3.25 and see if that helps. The modern fuel we run is 15% ethanol now, making stock settings lean to begin with. Your popping at idle (a lean miss-fire) is also a sign of a lean idle condition.
Old 02-07-2016, 03:30 AM
hmm's Avatar
hmm
hmm is offline
Starter clutch? When mine went, I had to wait ten or fifteen minutes for the bike to cool down if I had to stop for petrol etc, then it would start.
estate4life
05-17-2012 08:09 AM
Windsock209
07-22-2010 07:49 PM
RTrickster
04-09-2009 02:54 PM
pitbull#1
11-13-2008 09:02 PM
ffmedicgerbs
04-27-2007 06:37 PM
Quick Reply: To hot to start?
