hose replacement - carb rebuild
Cleaning up the carbs on my '93.
Check this part fiche , #32 bent hose.
Removed it, and #34, and they are hard as a rock (not surprised), but not cracked or compromised in any way.
What have folks done as a replacement?
Use a 90 degree fitting at the "bent" end and simply use 3/8" fuel hose ?
I thought it's rigid as a side effect of being subjected to constant heat like most rubber hose.
So if this is by design, and I see no cracking, am I okay?
How do I test for acceptible pliability ?
It's a challenge maintaining four different types of bikes with completely different technology and personality
(Hurricane, NC, ST, GoldWing)
on
well if the ends are cracked through to the insides at the T's then replace of not
carry on riding and I'd hold off trying a pliability test as bending it will probably
induce premature cracking given it's age(assuming it's an oem line/hose). Simply
put unless it's leaking at the T's reuse it.
