Help needed!
Help needed!
Hi all,
Been awhile since I posted on the forum.
Those that remember I have an engine of an F in a Locost kit car.
I needed to change the gear linkage as it has become worn out.
Ordered one off eBay which is perfect but I need to remove the pedal from the ball joint and then place onto a separate bracket.
How can I remove the pedal and reuse the pin any ideas how to take apart
Cheers guys and girls
Oli
A little pic
Oli
A little pic
Ball joints like that usually just pop out by prying. As the ball is welded on the pedal don`t really see any other option.
That`s a kicka$$ looking ride you got there, I did a track day last summer and those things were the fastest vehicles around the track. One even cracked it`s frame cause it couldn`t handle the hp:s the guy had put in it. Never told us what engine it had, never asked as I was busy getting to teh rtack and he was gone when I got back to the pits.
You don`t need to grind anything. Just take a flathead screwdriver and pry the joint off the ball. The new one should pop on by pressing with a pair of plumber`s pliers. at least that`s how you swap a gear shift link rods to a car and those joints are basically the same only smaller. If you weld the lug onto the arm whilst in the new joint you`ll no noubt fry the nylon insert in it.
I'm 6ft2 and it only ways 450kg so easy
I want to race it soon and you need a reverse.
Most use a starter motor on the prop :-)
I have always referred to it as a ball joint splitter though.
Same tool, different names.
