HAZARD LIGHTS
Old 01-06-2008, 12:44 PM
Shadow's Avatar
Default HAZARD LIGHTS
Does anyone know of a system for converting flickers/flashers/blinkers to hazard lights, so all flash together ?
Old 01-06-2008, 01:43 PM
Default RE: HAZARD LIGHTS
http://rattlebars.com/mtz/fourways.html
However, it seems to me this will drain your bike's battery in short order.
Here is an alternative that you may be able to stuff under the seat or strap under the battery box.
http://www.lcflight.com/flashlights.html
Hope this helps!
Robert Bashaw
LoweST Arkansas
Old 01-06-2008, 11:39 PM
Shadow's Avatar
Many thanks ArTravLr - just what I needed ! While we live in a pretty hot climate, sub-tropical, we often on early morning rides have mist to contend with, and really limited visibility. I have used a yellow strobe light attached to the back of my helmet, but it's not really the answer- 'specially when you forget to turn it off and get pulled over by "da Fuzz" - embarassing ! I'll have a go at this - many thanks again
Shadow1
Old 01-08-2008, 11:11 AM
TimBucTwo's Avatar
Shadow1,
How about removing the seat and putting a switch across the orange and blue wires of the ture signals.
Or running separate system of flasher lights. If it were me I would go to the auto stroe and buy some LEDs, a switch and a flashing unit and run seprate wires off the battery.
http://www.motorcyclelighting.com/
http://www.hyperlites.com/unikits.html
Old 01-08-2008, 11:29 AM
TimBucTwo's Avatar
I wasn't able to get the first link from ArTravLr untilnow.I like the setup with the diodes. That looks like it will work if you just want 4-ways. I think LED’s are much brighter and safer for you application. You may be able to use that system and purchase LED’s separately. The links that I came up with are pricey.
Old 01-08-2008, 11:22 PM
Shadow's Avatar
Thanks TBT, I'll weigh up the options and let you know how it turned out. At this stage, I don't have ANY power, as the stator's in for a rewind, and I'll check out the charging rate before I add anything else to the system.....I did the camchain swop OK last night, so nearly back on the road.....
Old 01-09-2008, 11:18 AM
I had my eye on this wireless LED system for a while. Seems that the light strips can be set to either brake or hazard mode.
The light strips run off watch type batteries, so I guess no drain on the 12 volt. I like it because it appears the LED light
strips can easily be placed most anywhere, say, sides of the fork legs or the sides of the grab rail for some side hazard
lighting. Up front, I'm thinking horizontally near the base of the windscreen may be a good spot. And at the rear, on the
back of my passenger back rest, or the fender. I received a return email from whitehorse gear today and they confirmed
that each light strip can be set individually to brake or hazard mode for whatever combination of lighting is desired. I'm pobably
going to try the base kit plus one extra light strip for now and see how well it works.
http://www.whitehorsepress.com/produ...oducts_id=5361
Here's a write-up about this system made by another company:
http://www.webbikeworld.com/r2/riderlight/
Also some cheaper and similar versions available on Ebay:
http://search.ebay.com/wireless-brak...sid=p1638.m120
Hope this helps.
Old 01-09-2008, 11:50 AM
TimBucTwo's Avatar
I have seen these on a bike just like mine. They cool like the cats meow.
http://cgi.ebay.com/ebaymotors/Rotat...QQcmdZViewItem
Here is another link.
http://www.ledshoponline.com/automotive_leds1157.htm
EDIT: I installed non-spinning ones after hearing about R/R problems and the electrical loads the system can handle. I now havea pair ofbright round running/break lights instead of the whole lens. I like the new look. It looks more modern.
Old 01-09-2008, 09:41 PM
Shadow's Avatar
Thanks all for the input - very helpful.
When I tackle the project, I'll do a step by step, with prices for compnents and so on.....
Old 01-31-2008, 03:57 PM
TimBucTwo's Avatar
I happened across this link and remembered that your bird had these bags. Maybe you could purchase the mounting kit for the 1kf and swap out the bags
and use this light kit with a separate flashing unit or modify the birds wiring and use it there. Anyway, another log to place on the fire.
http://www.twistedthrottle.com/trade...view/3979/681/
Edit: Fat fingers and small keys.
Quick Reply: HAZARD LIGHTS
