Grumbling rear brake
Hello all.
Just put new brake pads all round. Rear ones make a really embarrassing grumbling noise if I apply them gently. To avoid embarrassment I can only use the rear brake harshly (and skid).
Also grumbles sometimes when I'm wheeling the bike backwards.
They are Pyramid Parts. Had to remove some of the black plastic coating in the hole so that the retaining pin could pass through.
I also put Copperease on the rear surfaces.
Front ones are lovely.
Any ideas?
Thanks.
Any ideas?
Thanks.
How worn is your disc? A large lip on the outer rim might be touching in the pad before the actual braking surface. Aka bedding in but there's a spec how mugh wear is accepted in the rotor. If the lip is very big it might turn the pads crooked.
Last edited by Mattson; 09-26-2014 at 01:42 AM. Reason: not sure if proper english but youll get the point
Hayden06F4i
06-17-2008 09:50 AM
