FT Carb balance,How hard can they make it
After reading my Honda manual for sync'ing the carbs decided to have a go as i have a set of Carb tune pro gauges.The manual just says connect to the vacuum take off points,No1 being the fuel tap vacuum point.This is easy to find and get to,No 2 is on a flexy line with rubber cap hanging down between the carbs so found that one.No 3 is just a rubber cap onto the inlet,impossible to reach unless the fairing comes off and no 4 is a M4 cap head screw into the inlet stub.Took me 2 hrs just to get at the connectors and then when connected up you cant reach the adjuster screws on the throttle links without a special tool.Why not have a rubber hose with a cap on like no2 carb on all the carbs clipped up on top so you see all of them and actually connect your gauges easily.It has wound me to a frenzy,it should be a simple job to do.Thats it moan over.
Hey Mr C, if it was easy every one would do it!
Did you look at Naga_Thai's fantastic "How To"?
https://cbrforum.com/forum/how-tos-8...ctures-115891/
Cheers, SB
Cheers, SB
