Front brake line
Old 10-05-2010, 08:13 PM
Sprock's Avatar
Lightbulb Front brake line
Off the bat........
About how much slack can you get out of the stock front brake line .?
Trying to figure out how much rise I can plan for with a new set of
Riser clipons ? LSL , Woodcraft, Convertibars etc.
Leaning towards a woodcraft 2 1/2 inch set. ....... Just wondering !
Old 10-05-2010, 08:47 PM
pacojoseph's Avatar
From my experience with my 95, I'd say you're asking the wrong question. I run out of throttle cable slack before the brake line goes. I'm running adjustable bars with about a 4 inch rise over stock, at the bar ends, with the stock lines, but, this number may not be applicable to other bars. Heli bars, for example, I think have a rise in the bars at the clamp, while my bar height at the clamp is close to stock, so I'm not really needing much longer lines to get this rise.
Old 10-05-2010, 10:15 PM
Michelle's Avatar
I had to run everything round the outside of the fork tube and undo the top clamping bracket to release the brake hose to fit the VFR bars. Seemed ok for a temp fix, as I want to replace all the lines anyway.
Old 10-06-2010, 06:56 AM
Sprock's Avatar
Thanks , pretty much answers things for me. So I should be okay Paco with a 2 1/2 or 3 inch rise then. Good ideas there Michelle outside the tube that is ......maybe I'll fab' a bracket/clamp or something for the outside run somehow.
Old 10-06-2010, 07:55 AM
Michelle's Avatar
I took a piccie for you ... there are 3 clamps on the hoses. We just took out the middle one and pulled the line up a bit.
The throttle cables seem quite happy to sit where they are, although I have them tied to the wire for the grip heater.
Attached Thumbnails Front brake line-frontbrake_0079.jpg   Front brake line-frontcable_0080.jpg
Old 10-06-2010, 12:37 PM
Sprock's Avatar
Very good Michelle, yeah that seems verrrry doable Thanks again
Lildude71
03-08-2011 11:05 PM
dwarfdwarf
08-17-2010 03:52 PM
RYDINRED929
08-17-2008 12:55 PM
Scrufdog
09-26-2007 02:55 PM
Quick Reply: Front brake line
