Fried connector - alternator - starter motor
Hi all
F-L 1990 finally refused to start yesterday, after a period of poor starting when cold and NO starting when hot. So decided to have a look at the starter clutch.
Removed tank, carbs, airbox, no problems so far. But when I got to the alternator cover:
1. The three allen bolts are really really stiff - is this usual?
2. I couldn't separate the two parts of the red connector at the end oif the wire coming from the alternator cover. This is because they were MELTED together and when I did manage to prise them apart the insides weren't too pretty.
Is this due to repeated 30-second attempts to get her started? Or to repeated jump-starts from a car battery? Or to a bad R/R (have just got a new one)?
I'll probably bare all the wires and join them with separate connectors - like I have already done with the starter relay!
Is it worth my disassembling the starter motor to check the bushes? Is it possible to hook up the starter motor directly to a battery to see if it spins OK?
Thanks again all.
Thanks again all.
Oil in generator cover - alternator stuck
I'm getting there slowly...
Took off the generator cover - is it OK if there's a bit of oil in there? The coils look OK, all pinky-beige, no obvious signs of being burnt out or am I missing something?
Now trying to remove the generator. I'm pulling the generator out and it looks like the starter clutch is coming out too - e.g. a big brass sprocket is coming out too. Is the generator supposed to come out with the shaft bare or with the sprockets etc on it?
I ask because something is stopping it coming all the way out - it was getting dark at this point and the groceries arrived so I shut up shop for the night.
Thanks all!
Thanks all!
Er, no, but that is probably because I'm stupid and am following the thread 'http://www.stu.co.nz/cbr1000fix/' in strict sequential order, even though I've read through it a few times!
So I didn't read the bit about the tab before I started to try to pull the generator out. (Like I didn't put the bike in gear before I started!)
When I pull the generator out now, it comes out with the big cog and the thing behind it (looks like a sealed bearing). The small cog and damper don't appear. If I push the generator back in and bend the tab down will the whole lot come out?
Thanks!
Only 6 plates not 7 in the damper?
Got the alternator damper out.
It rotates smoothly on the alternator shaft. And the central shaft moves in and out 1 or 2mm. And there are only 6 metal plates plus the thick one under the springs. I thought there were supposed to be 7 plus one?
I'm going to fit a thick washer - should it go under the thick metal disc after the top three springs or should a fibre one go first?
Also I found two half-circle shims inside the damper case after I pulled the central shaft out. I presume these are not broken and fit around the thinnest part of the shaft?
Thanks.
Thanks.
Fit the metal washer on top
Correct, they fit in a slot at the bottom of the shaft
