Fork springs?
Old 11-07-2015, 12:44 AM
TW's Avatar
TW
TW is offline
Default Fork springs?
I'm rebuilding forks over the winter. Any recommendations or experience between race-tech or progressive suspension springs (87 Hurricane)?
Old 11-24-2015, 08:22 PM
tomttt's Avatar
Just rebuilt my 96's and installed new progressive, very happy with them. Also used synthetic ATF. Front end is tighter and plusher. I had cut OEM springs so I can't compare to the race-tech.
Old 11-27-2015, 11:54 AM
TW's Avatar
TW
TW is offline
Thanks! I think that's the direction I'm headed and will do the same.
After looking more at race-tech, seems like it's more than I want to deal with.
Old 11-29-2015, 09:23 PM
tomttt's Avatar
TW my bike had 50K miles on it when I had a seal start weeping so I changed out most parts; springs, bushings (x4, 2in, 2outer) new seals and wipers. I went with all honda OEM other than spring and oil. Rode today, plush over small bumps and controlled at speed. Much less dive also.
Old 12-09-2015, 03:00 AM
TW's Avatar
TW
TW is offline
tomttt, my 87 only has 31,000+ but seal are leaking a little. I have all new seals and bushings ready but need springs. Rides really plush after swapping 1990 wheels and radials but forks starting to bottom out on the freeway at speed with big hits over crappy surfaces. Hoping new springs and oil will stop it from bottoming out.
Old 12-10-2015, 07:22 PM
tomttt's Avatar
After my "rebuild" mine feels like it is higher in the stroke, but I feel bumps less and less dive. Overall Very happy wit results. My 96 called for ATF or fork oil, the syn Mobil one filled to recommended level seems just right.
At this point I have no reason to go any further with modifications.
I also put the progressive strings in my 96 1500 Wing SE, (only has 10K on it now) and OMG transformed the handling of the bike.
R1000
12-09-2006 03:03 PM
davethepom
11-15-2006 01:32 PM
kevinedgington
09-15-2006 11:54 PM
pilam
05-12-2006 10:16 AM
Dstudebaker
11-28-2005 09:10 PM
Quick Reply: Fork springs?
