? ever come across this issue
Old 01-12-2014, 07:53 PM
Sprock's Avatar
Question ? ever come across this issue
When I start my 93 and it's on choke, not quite warm and I gun the throttle
between 4k and 8.5 k the low beams drop out ?
When it's on high beam (same scenario) does not happen at all.
When bike is fully warmed up does not happen on highs or lows !
What ya think ? Bad high / Low switch ?
Old 01-12-2014, 09:38 PM
Sebastionbear1's Avatar
If the low beams drop out completely - I'd be looking at the switch.
Or like me, do they just dim with revs??
Cheers, SB
Old 01-13-2014, 11:31 AM
pmcg's Avatar
I notice my lights dim when my revs drop approaching a stop.
Old 01-13-2014, 12:52 PM
TimBucTwo's Avatar
Sprock and Sebastionbear, IMO sounds like switch.
pmcg, battery on way out or you need to upgrade R/R, most likely R/R.
Old 01-13-2014, 01:38 PM
Sprock's Avatar
No Dim ( it's how I roll ) no they just drop out - I'm thinking the switch or a
short somewhere
Old 01-13-2014, 03:34 PM
hmm's Avatar
hmm
hmm is offline
I got a new R/R but the lights still dim (noticeably) at idle.
But the battery stays charged so I'm not that bothered.
Old 01-13-2014, 03:48 PM
HenryM's Avatar
Change the low beam relay. Mine packed up in a similarly strange way.
If main is fine then you don't have any other electrical problems to worry about.
Old 01-13-2014, 04:57 PM
Sprock's Avatar
What I was looking for Thanks Henry old Son
Do ya have a part # per chance ?
looking at the online Diag I see relays but they are listed as starter relays (guessing that's wrong )
http://www.partzilla.com/parts/searc...ESS/parts.html
Old 01-13-2014, 05:55 PM
HenryM's Avatar
I've just looked at the fiche and they're labelled incorrectly. There are two relays side by side under the front cowl to the L/H side behind the speedo. The parts list calls them starter relays but they are hi and lo beam relays. Tsk Tsk Mr Honda.
Part number is 38501-GN2-014.
I'm sure there must be loads of these knocking around at breakers. Alternatively you could probably use a standard relay. I was lucky enough to have another one to hand.
Swap over the hi beam relay onto the low beam plug or visa versa to prove fault..... T'be sure etc.
Old 01-13-2014, 06:11 PM
TimBucTwo's Avatar
Good thought there Henry. I have never been that deep into the electronics on these bikes and wouldn't figure a relay but, hey, they drop out during cranking.
Quick Reply: ? ever come across this issue
