DYNOJET Jetkits
waste of money. i bought it, then rejetted the bike with the stock needles and jets and it ran much better. it pulls like a damn train past 8k, even with a 100% open intake (i have no filters or anything, just the carbs open) and a full V&H exhaust. im running about 13.5 AFR up top (yes, i have a wideband o2 gauge on my bike) with the stock jets.
I wouldn't bother either. I fitted a stage 1 kit to mine when I fitted my V&H and K&N. I ended up putting the original springs back in because the new ones were too light. When i cracked the throtte open there was a lag before the power came on. It runs a treat now.
If you fit a free flowing pipe you'll probably need to fiddle with the mixture a bit but, if it runs fine now and isn't lean, spend your hard earned $$ on something else more worthwhile IMO...you know...beer, chicks etc.
With what you're describing, stefan, you'll probably need to invest in a kit with adjustable needles. I have a faint memory of somebody shimming the standard ones though.
Whilst it might seem to run ok, if you run it lean (and it probably is with that nice free flow of air) you'll kill it in the long term.
Find a good tuner with all the testing gear and get it set up properly.
Oh yeah stefan; don't tell the other guys I said this but I like the look of your fighter.
I'm not telling
And yeah, it's running a bit lean, though I did plug two vacuum ports the previous owner left open, and will gear up in a few minutes to try it out again, see how it runs... but I'm sure it needs a tune, because of the free flowing intake/exhaust.
It idles smoother, so I hope it'll be an improvement.
