Drilling slides
on
Drilling slides
It's a much discussed subject on a lot of Forums. Some jet kits come with
drill bits some don't. Some Jet outfits promote drilling slides , others warn
against it - saying once drilled you cannot go back - (which is BS all you do
is epoxy the drilled hole and re-drill a stock size)
Just wondering any one done it the their Hurricane ?
Anyone have opinions on the merits of doing it ?
on
there's a little breather hole in each carb piston/slide Bordo that serves as a pressure
equalizer / regulator that dictates how quickly the diaphragm / slide / needles raise
or lower when you twist the throttle
Some say enlarging that hole can lead to quicker response time and by default better
throttle response - but then some say otherwise - just wondering if any "old heads"
here had tried it out.
Might get a set of used slides and give it a go to find out if this thread comes up zero.
Having rejetted my 90 last year I'm thinking she may benefit from this only one way
to know - someone has done it - or as I said give it a go myself
upgradedcbr
01-14-2013 10:20 PM
