Coolant thread
Coolant thread
OK we've had the oil thread so how about the coolant thread
I read the label on the coolant bottle I bought last year and it clearly states "suitable for most vehicles built after 1998" !!
I've been using a general coolant for cars and bikes but now I obviously need to pay more attention to what I buy.
You guys any idea why a statement like that is on the label, any particular additives to avoid etc...?
John
John
Here's my guess John, and I'm prepared to be shot down!
1998 give the coolant manufacturers a clear date for cut off regarding older, more problematic vehicles. That is the older the car the more likely its cooling system is not going to be up-to-spec and therefore give problems. Saves grief for the company??
All I know about coolant is, make sure you thoroughly flush the system before changing coolant types. Keep the mix right, levels right and run a coolant expansion tank.
Cheers, SB
Cheers, SB
OK, I'm going to shoot myself down!!
Interest got the better of me so I did a search, came up with the following.
"Therefore you should ALWAYS use the antifreeze recommended by your car's manufacturer, or one that meets all of the specifications laid out in your vehicle's handbook. Antifreeze should always meet minimum recognised quality standards such as BS6580:2010 or ASTM D 3306 (one of which should be written on the packaging).
As general guidance, cars made after 1998 normally require antifreeze that uses silicate-free, organic acid technology (OAT), which offers superior corrosion protection and does not need to be changed as frequently as 'traditional' antifreeze.
Cars made before 1998 usually require conventional antifreeze that isn't OAT-based and does contain silicate. Again, always use your vehicle's handbook to verify this."
Apparently it OATs
Cheers, SB
Apparently it OATs
Cheers, SB
I'm using local stuff so no idea what's in it
I think using distilled water helps a lot with corrosion too. I've not had a coolant problem except for a blown T piece a couple of years ago when replacing the thermostat.
I use 50/50 mix. Having said that it doesn't get cold here like most of you have in winter.
I use the Red coolant (NULON) premix..... green is good for veh's with copper / brass radiators however your bike's cooling system & engine is mostly aluminium
Red is Ethylene Glycol / deminerlised water 50/50 mix with OAT " organic additive technology" ( alot of people bitch about paying for 50% water) however alot of people get the mix wrong and destroy water pumps as well.
Green is just as good it's just old school M.E.G "mono ethylene glycol" however it doesn't have the 5 year lifespan of RED.
cheers pete
cheers pete
