Cold coolant leak?
Cold coolant leak?
Rode in to London today, traffic very very heavy (tube strike), engine hot, fan on and off but didn't go anywhere near the red zone. Parked up and noticed a few big drops of liquid under the bike but no dripping.
Dripping started when I started the engine. It's coolant, but it's cold? Even with the engine very hot?
I fitted a new thermostat recently but the leak is not from there.
I fitted a used water pump last year - perhaps that has gone again?
Haven't crawled underneath to have a look but suggestions will be welcome!
I intend to ride her home tonight - air-cooled - after the traffic has died down!
had the same with my mark 1, turn it off and drips, is it comming out the overflow pipe, check where its routed, for some reason the pipe through the cap into the tank on mine went right to the bottom and when she warmed up the level was enough to push water out through the overflow, so i cut it off on the bottom level, and no more drips, have checked the tank a few times and the level is ok,
Tim, thanks for the info but the pump was fitted many months ago with new O-rings (the big one and the chrome pipe one), and it's been OK until today.
