Clutch Help
Old 04-29-2013, 02:25 PM
HurricaneChuck's Avatar
New Member
Default Clutch Help
I have an 87 1000F and when I pullled the clutch handle in for the first time this season.... nothing... Hmmm.
Does anyone know if this is an air in the line issue, i.e. one that can be solved by bleeding? Or did something, like a seal, pop over the winter?
Any advice is totally appreciated.
Thanks
Old 04-29-2013, 05:15 PM
Sebastionbear1's Avatar
G'Day Chuck,
It could be a number of things.......
1. Clutch fluid drained out over winter - check for leaks at the clutch lever and at the slave cylinder. Renew fluid and bleed system
2. Clutch pushrod seized - there is a 'how to' on the site on how to remedy this and refurb the slave cylinder.
3. Clutch plates may have seized together over the winter. Take off the side cover and check/loosen plates.
Let us know how you go.
Cheers, SB
Old 05-02-2013, 07:28 PM
MadHattr059's Avatar
If it's a hydraulic clutch, it should have a fluid drain and replacement/bleeding (at least every-other year).
Just like the brakes, the fluid is hydroscopic and will become contaminated with water-vapor, over time.
If it's been a while, I would make that the first thing to try.
It's cheap and is a better solution than just doing an air-bleed.
Good luck, Ern
Old 05-02-2013, 11:47 PM
Shadow's Avatar
Could be air in the master cylinder due to a seal issue in the master cylinder.
This would be the first place I'd look.
Try pumping the lever and see if you get any pressure.
If not, I'd bleed the brakes.
Old 05-08-2013, 10:08 PM
Sprock's Avatar
S'up Chuck ? Where in Taxachusstts ya hail from?
anyhoo
Slave cyclinder seal at the sprocket cover is blown - usually
oops I see just like Seb mentioned
Old 05-10-2013, 07:26 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
An interesting solution there Pete.
You do realize don't you, that the Mk1's don't have linked brakes?
Chuck, if you do get for a total fluid replace as the wise man Ern has suggested, temporarily top up the master cylinder with meths.
It gives you a good color break, so that you can see when all the old fluid has come through, and then when the new replacement fluid starts to come through.
Zandaloo
08-22-2013 03:26 PM
Bordo
09-21-2012 07:33 PM
02f4irider
03-06-2009 07:50 PM
red stinger
07-19-2008 12:17 AM
cyber00677
06-23-2007 06:17 PM
Quick Reply: Clutch Help
