chain engine
chain engine
I have set in motion the my cbr 1000 f 1987 and the engine proved noisy. I consulted a honda mechanic who suggested I replace the chain and tensioner distribution. I performed the work but the typical noise of the chain remained. I consulted again honda mechanic and advised me to replace the two smaller chains mounted on the motor shaft. To perform the job told me that you need to go down and open engine. Now I ask the readers that are practical: you can run the job by removing the under oil cup? I can work on the chain tensioner? excuse my english bad. thanks
Using standard Honda oil chain you cannot replace the chain without stripping the entire engine. Same problem if the tensioner on the oil chain goes, which is what I think is your problem.
If you replace the chain be sure to replace the tensioner when the engine is stripped.
If you can find an oil chain with a split link you will be able to do the replacement, but so far I haven't found a manufacturer who makes one.
If you find one, please let us know.
YOu won't know until you at least look through the pan I believe. The task is really tedious and a bit expensive. The bike has a lot of bits on it, comparing to my old CX it is like a walk in the maze without an exit...
That's not the worst I am afraid, I think if the chains get shot it's like honda wants to tell you, don't repair me, just buy a new bike. I am very scared of what I am going to see even if I decide to lift the crankshaft out, what if I see half worn plane bearings there? Am I to buy new ones or simply dispose of her?
The cost of repair may finally equal half the price of a newer bike... but that's just the choices...
The work I have to do it alone without help. So cost zero. The honda does not provide for the replacement of the distribution chain open. To replace the upper chain, with an open and rebound, coast an hour's time. To replace it, as recommended by Honda, it is necassario dismantle the bike. So to replace the bottom chains I will use the same method. I do the maintenance and not the honda. The chain is built in pieces and how it is constructed so will open and replace it. The board was requested only by those who had carried out the work with the mode "economic". there is someone who has done this kind of work? thanks
I've replaced the starter clutch on my bike. The only way to get to the oilpump/alternator chain would be from the oil pan - there is no place to work behind the alternator, even with small hands. The chain is also under tension from a tensioner behind the alternator (this part often fails)
I have not removed a link from the oil chain but if you can do it successfully, it will be the first time anyone on this forum has done it in the 10 years I have been here.
Oil pump chain replaced without opening the engine. I disassembled the oil pan, I opened the new chain with the chain unravels. I disassembled the gear pump, I opened the old chain and the thin metal wire I connected the new to the old. I entered high gear and turning the wheel back I changed the chains. I closed the shirt of the new chain, I reassembled the gear pump and I restarted. The noise was not complaining that the oil pump chain but the generator. I'll have to dismantle everything. greetings
