Carby bowl Gaskets " HELP"
G'day All
I have just purchased an 89 1kF / K? red/white/ blue
My problem is some muppett has sealed the bowls with silicone which has found its way through virtually evey jet in the carb's
now I have checked for gaskets for this & they are genuine $55 per rooster or are the gaskets for the 87FH & 88FJ models the same as they are available for $7 non gen.....or can someone steer me in the right direction for non gen FK gaskets.
Cheers pete
Cheers pete
42 views & no response...well I have found a supplier in the UK $50 for all 4 delivered to OZ & they have all models covered
NRP Carbs and Diaphragms
cheers pete
cheers pete
Blimey Chimp, your thread must have been stuck in a time vortex. Most unusual that no one heard you calling for help.
Try David Silva spares or Wemoto. Both good UK outfits but happy to ship abroad. Always keen prices.
Bad luck on the lack handed approach of the PO. It happens.
There are lots of guys here who know their stuff when it comes to carbs. I hope one of them has the time to add some wisdom from experience.
It should all clean up nicely when you've got the parts in your hands.
Good luck
H
Good luck
H
Good luck
H
Good luck
H
pete
if you want to save some $$ and the current gaskets can be cleaned good enough
you could reuse the old gaskets sammiched between this stuff LINK
it specific for Motorcycle Carb Gaskets
Ya might save about 140 bucks
Cheers
pete
G'day Ranchome, Naga Thai set me straight on that score... I have tin tops so gaskets 87-90 should fit which are local & 7 bucks each & if it all turns pear shaped I have the gaskets coming from the UK ,,, the local ones arrive tomorrow am so I will post either this time tomorrow or the next day
Cheers
Pete
Cheers
Pete
Well there ya have it....it purr's like a kitten! 87-90 gaskets fit & no problems...BIG thanks to Naga-Thai for your sage advice..catch up for that beverage (on me) $ cost of Gaskets was $22Aud from Dynoverks in Melbourne opposed to Genuine $220Aud.
Very happy camper.
Cheers
Pete
Very happy camper.
Cheers
Pete
Brilliant Pete - and isn't Naga a dyed in the wool gem! I'll have to get some of those $22 gaskets I think.
Cheers, SB
