Carburator Tune-Up
RE: Carburator Tune-Up
It's quite easy to take the carbs off, and cleaning the carbs is simple. If you have a manual. You probably have dirt clogging the inlet valve above the float. I use a large metal baking sheet, with turned up edges, for cleaning. You don't have to take the carbs apart from each other. Use a very good phillips screwdriver to take off the screws. Use spray cleaner to clean the jets and passages. Then take the tops off and clean the plastic slides, walls and passages. Don't get carb cleaner on the diaphram. Put a little Vaseline in groove to hold edge of diaphram. Done. First time is the toughest.
