Carbs rebuilt but...
Old 08-10-2012, 05:44 PM
pmcg's Avatar
Default Carbs rebuilt but...
So I just finished rebuilding the carbs on my 87 1kf but am having an issue. The bike starts fine with the choke but any time I give it any gas it dies. I set the pilot screws at 2 1/2 out. I tried the carb sync but wasn't getting enough vacume to calibrate the tool. Bike never ran without the choke. Any suggestions are appreciated.
On a side note I had no idea that there was a small filter located under the float pin. If anyone has a tank spewing rust and gunk I would check these guys
Old 08-10-2012, 05:58 PM
cobra1000rr's Avatar
sounds like its starving for fuel, check your tank and make sure its not clogged up.
Old 08-10-2012, 06:04 PM
pmcg's Avatar
I'm using an auxiliary tank so I'm sure the fuels getting there. But I agree possibly starving for fuel I just don't know why.
Old 08-10-2012, 07:03 PM
Hueristic's Avatar
Thanks for this, I have my carbs apart right now and read about these filters and completely forgot to do them! Sorry I can't answer your question though.
Old 08-10-2012, 08:40 PM
pmcg's Avatar
Glad I could help. Do you know how many turns out your air/pilot screw is?
Old 08-10-2012, 09:01 PM
Hueristic's Avatar
I'll check in the am for you. I have not touched them.
Old 08-10-2012, 09:02 PM
pmcg's Avatar
Thanks. Let me know if you need any parts as I have 2 donor sets.
Old 08-10-2012, 09:05 PM
jarvid's Avatar
Welcome Crew
My pilot screws are set at 2.5 turns when the bike was rejetted, they were at 4.5 turns(so the mech said).
Old 08-10-2012, 09:15 PM
pmcg's Avatar
Thanks Jarvid I'm pretty sure mine were at 3 when I took them out. I should have paid better attention. Seems odd that you would need a leaner mixture after the rejet. How the bike running after the big rebuild?
Old 08-10-2012, 09:24 PM
Hueristic's Avatar
Do you have a picture handy pointing out the correct screw?
Quick Reply: Carbs rebuilt but...
