Can someone give me some info that has cut the rear off of the factory muffler?
Old 11-09-2016, 04:30 PM
amanda11270's Avatar
Default Can someone give me some info that has cut the rear off of the factory muffler?
I just recently purchased a 1988 Hurricane 1000 that is in just incredible condition. However a previous owner has cut the centers out of the rears of each muffler.
I did some searching and found a photo of this modification, however I actually want to make mine back to stock. I can fabricate and weld extremely well, I restore vehicles as a hobby often.
What I actually need to know is, when you remove the center of the end, the tube that is in the center or the actual exit pipe, it appears to go into one of three chambers a few inches inside the muffler. Which one does it go in? If I had to guess, it would be the top hole, as its different from the lower two on each side if I remember correctly.
My mufflers are in excellent conditon and extremely shiny still, any ones I see on ebay that are complete are either rashed or repainted, I would rather repair mine as its an easy fab and weld project to remake the ends.
Old 02-08-2017, 08:46 PM
silverf1's Avatar
I have no clue, and I know this post is several months old, but if I where to try to come up with any kind of help.... what about picking up a ratty one off of ebay if you can get it cheap, then cut it up yourself and taking a peak at how the insides are routed?
cascenico
04-14-2011 11:55 AM
cascenico
04-14-2011 06:45 AM
phokoff
01-25-2008 04:46 PM
ptowntsi
10-01-2007 05:49 PM
scatman
04-19-2007 01:11 AM
Quick Reply: Can someone give me some info that has cut the rear off of the factory muffler?
