Can Battery acid go bad?
So I bought a new Chinese battery for my bike today that came with own bottle of acid to be added before use. The only problem I have is that there was not enough acid included to fill all 6 cells to the upper level as the instructions call for. WTF. Anyway, I found an old container with acid that was left over from an previous battery install. The container was plugged pretty good so I think it's clean, but I have no idea how old the acid is. It could easily be 4 or 5 years old, maybe older, maybe much older. Is there any problem with using this old acid to complete filling up my battery? I need an answer quick. I'm in the middle of this.
The quick answer is that the acid must be "topped up" with distilled water.
Battery electrolite (fluid) is NOT all acid. The electrolyte is made up of 35 percent sulphuric acid and 65 percent pure water.
Ref for overview: http://www.rpc.com.au/products/efn/e...ries_care.html
"For most typical motorcycle batteries you will need around one litre of "acid" ."
http://www.mdsbattery.co.uk/shop/pro...ctGroupID=1038
The instructions say to fill each cell to the upper level with electrolyte, let it sit for 1/2 hour, then refill again with electrolyte if the level falls, then charge the battery and THEN fill with distilled water if the level falls after charging. Anyhow, you didn't answer my question. I'm not topping off. I'm doing the initial electrolyte fill, but the battery only came with enough to fill 5 of the 6 cells. I want to fill the sixth cell with way old electrolyte. Is this a problem?
Guest
Posts: n/a
Mate .. acid does not go off if it has been sealed when stored..
The only thing than can happen to acid is that it might dehydrate and become a touch more potent and if left for long periods open will go a weird color and the dregs will finally go gooey,,, (then its dead)
If the acid in your container was clean and clear ....it will be quite ok....
The "Curse" of the cheaper China battery............I come unstuck a few times using the cheaper brands.Flat-charge-Trickle-Distilled Water= A battery full o Moonshine.
Get a decent brand,cost will outlive all the dramas of having an inferior product.
Temperatures in YOUR area will play an important part of the life of the Battery.
Guest
Posts: n/a
Storing of your battery acid
Battery acid is indeed made up of a 35% sulphuric acid solution. The best container to store it in is glass. If you stored your "battery acid" in a clean container out of the sunlight where it is cool, you solution should last well over 5 years. IF the container was open or exposed to the air, the solution could evaporate (go above 35% solution) or since Sulphuric acid attracts water, it could be diluted (weaker than 35%).
CBRclassic is right, use it if it was stored correctly.
Since you ended up with too little solution, my thoughts would be that the original solution would be questionable (either too strong from lack of water or just not measured right from the chinese kid who is working with only one arm to make it in poor working conditions). A battery tester that tests specific gravity would tell you if the solution is any good (both the original solution and the stored solution). Sulphur acid solution should also have a PH of zero.
To answer your question directly, use the stored solution it should work as CBRclassic said.
Well I used the stored solution, charged my battery overnight, installed it, and my bike started right up- and was noticably cranking faster than it has in awhile before catching. Anyhow, the battery I replaced was Chinese and lasted about 2 1/2 years- and I'm notoriously bad at maintaining my batteries. I was wheelless without my bike, and I got the battery at the third closest auto parts store to me- the closest two didn't have the right battery for my bike. There are no cycle dealers (expensive) close to me, and I didn't really want to order online cause that would have kept me off the road for another week. Anyhow, I got the battery from Pep Boys (a large auto parts chain in these parts) and it has a 90 day warranty and was cheap, $35 plus tax, cheaper than anything I found online, including ebay. So, I've got my fingers crossed, and I'm happy right now, especially since I'm back on the road. Now it's time for a ride.
on
1 Post
I wouldn't worry so much about cheap - or chinese - I've had very expensive batteries go bad (Usually just out of warranty) - the weather and temp where you live will have more effect - Extremeties in short periods of time murder a battery.
Very hot days and very cold nights are the worst
Happy Biking
Happy Biking
