88 Hurricane Headlight Problem
Old 12-01-2011, 10:42 PM
mccrystal's Avatar
Default 88 Hurricane Headlight Problem
Hey everybody,
I bought a 1988 Hurricane 1000F recently and got it running and everything but I can not get the headlight to work. I took apart the starter switch to make sure all the wires were connected and they are...what next? I dont know where the relay is or how to test it. I need help so I can get out there and ride! Thanks!
-Matt
Old 12-03-2011, 07:16 PM
yz125's Avatar
Well, do you know the bulbs are good? Have you measured the connectors to the headlamp assembly with a voltmeter to see if they have power?
Old 12-03-2011, 07:20 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Does the high side work.??
Old 12-04-2011, 08:57 AM
mccrystal's Avatar
Thanks for the replies. I took the starter switch apart and put it back together to check for loose wires and now the light works! Maybe something was just loose.
Thanks again. I will be looking to your advice for the future!
hard2obtain
06-18-2011 09:12 PM
isisjessie
07-23-2010 09:25 AM
talonsport
07-05-2008 11:09 AM
Gearloose
10-16-2007 01:24 AM
Quick Reply: 88 Hurricane Headlight Problem
