Black filth
Old 08-31-2010, 06:14 AM
DragonCBR's Avatar
Default Black filth
hey guys
anywone knows how to get rid of the accumulation of black filth due to 23 years of internal combustion?, Whenever I open the motor I do not burn oil , but leave a trail of black postcombustion particules LOL
Old 08-31-2010, 07:20 AM
TimBucTwo's Avatar
Originally Posted by DragonCBR
hey guys
Simple, you need to open her up more to clean it out. It's probably corn cob build up from the crappy fuel these days.
Old 08-31-2010, 11:06 AM
DragonCBR's Avatar
Yup
but was wondering if there is a way of doing it less violently...
Old 08-31-2010, 12:09 PM
PlayfulGod's Avatar
sounds like the inside of your pipe is coming apart to me lol
Old 08-31-2010, 03:21 PM
TimBucTwo's Avatar
Yup
I could do it for you......
Old 08-31-2010, 04:59 PM
kilgoretrout's Avatar
Administrator - Retired
Run an open header and you'll never see it.
(although you'll hear it...lol)
Seriously, though, there isn't much you can do about it other than opening it up more often. You're likely running a bit rich, too, so maybe a less restrictive air filter.
Old 09-01-2010, 02:01 AM
Shadow's Avatar
Most of it's probably coming from inside the exhaust. It needs to be knocked loose or burned loose. Here the guys use a torch, heat up the pipes and bang them hard to loosen the cr..p .......
(Same style as we used to use with 2 stroke boxes back in the day)
FWIW
2c worth
Old 09-01-2010, 07:03 AM
DragonCBR's Avatar
mm I won't bang on my Supertraap, guess i'll need to find anoher way, mm not running rich it is stock so i guess i will not open her in front of a cabriolet.
LOL
Old 09-01-2010, 09:31 AM
TimBucTwo's Avatar
With that said, That's what may be causing it. I have seen other bikes with super Trapps that look like the post combustibles build up in the disks. The exhaust is dispersed 360° through several disks and you don't get a high enough flow to keep it clean at low RPM. I think it's normal.
Old 09-01-2010, 10:07 PM
Shadow's Avatar
Maybe use oven cleaner - then wash it out........................
Quick Reply: Black filth
