Ask the Experts, she puked antifreeze down my right leg..
Noticed a few weeks ago when it was 90 degrees and humid the bike would run hot at idle then cool off after I got moving. Last Saturday I got caught in the rain for 2 hours on the way home after installing a new front tire. Finally hit dry roads and let the old gal rip, she puked down my right leg.
Since I am dealing with a 1993 and no history of repairs, me being the third owner and almost 20 thousand on the clock. What would you do? I am thinking the thermostat is stuck open and the over flow tube may not be attached.
I am busier than ever and have no time in the near future to get all the covers and fairings off so I can see what is going on but I can start ordering parts. Would it be safe to suggest replace all the hoses, thermostat, and water pump? Or am I jumping to conclusion?
on
I'd say the 3 way plastic T (a common problem ) has let go - not a big deal
ITEM # 20 in this diag , $16.27 plus shipping
http://www.partzilla.com/parts/searc...TOR/parts.html
After diagnosing the true nature of your problem, you might get a new radiator cap as well.
Once you get the tank propped up, you can open the radiator cap and you should be able to see part of the thermostat. While staring down the hole, run it through a warm-up/cool-down cycle and you should be able to tell if your thermostat is working
Go to your local auto parts store with cap in hand. Ask for a radiator cap for a 1997 Ford Explorer with a 4.0 SOHC 6 cylinder. That's the cap that fits on my '87 1kf.
You'll want one that says 16 psi or 1.1 bar.
You can save almost $10.00 over ordering it from a Honda parts house.
If you don't know that bike's history, a complete flush is a good idea
You guys are amazing and that is why I like these forums. Yes on my fan working, the bad, I just filled the tank. The Detroit Credit card trick will come in handy to siphon the gasoline out so I can lift the tank.
I did see multiple threads on replacing the radiator cap, will add that to the list. I just have to find time in the short near future since I miss riding.
If you gentlemen ever need Ford Diesel advice, just ask. I am a Moderator on Ford forum. I value the information that a group of enthusiasts can gather and share.
On Edit: I forgot to mention, when I do inspect the 3-way T it could have prevented the system to build pressure but not leak. I have seen this type of scenario before. Prior to the engine running hot, I was already looking for a suspect but I think it found my leg.
Simle fix, check if the overflow tube goes all the way down in the reserve thank if yes, when the bike is running hot and the system send coolant in the overflow thanks, since the tube is all the way too the bottom, it 'thinks the thanks is full, thus sendin the collant out,. had this on mine, i cut the tube halfway, i know Shadow did the same at one point.
also makesure the over flow hose is not cracked or dry anywhere .
My two cents.
My two cents.
1993 Honda CBR1000F A RADIATOR | MRCycles
Just like to add, as it's a '93 bike the radiator cap and thermostat is located under the small panel under the right hand clip on, not under the tank like the MK1's. Take a look at the parts fiche in the link (part Nos 7 & 17).
I have sworn an oath to the MkI, therefore, I do not consider the differences in other years
