Alternator O ring failure?
Greeting all I recently purchased a 96 CBR1000f with the intention of preparing it for a cross country trip.Cosmetically shes pretty rough but she runs and rides beautifully. But yesterday I discovered an oil leak. I traced it back to the the alternator and when I took off the cover sure enough the o ring was completely toast and in about 10 pieces. This seems kinda odd to me since the bike only has 13k on it. Has anyone else had this issue? Im a little worried the previous owner may have put some weird additive in the oil maybe? Im doing an oil change today but Im still a little worried about my other gaskets
There's a big O ring around the alternator. Sometimes they can be inserted incorrectly and damaged. I don't know of any oil additive which would cause an o ring to crumble, but some proprietary cleaners aren't good for them.
I'd buy a new one and refit...............ALSO - recently we had a member who had his oil thinned out due to petrol contamination - you may want to check your oil and replace it.
I corrected your original post
Here's where you can buy a new O ring for under $9.........
http://www.cheapcycleparts.com/oem-p...ane/alternator
It's your choice - there isn't high oil pressure into the alternator see if you can find some O-ring in the correct diameter you may be OK, but joining the units with "make a gasket" isn't a good idea - very hard to separate them later, and they could crack when you try to pry them apart, then you're in for expensive stuff..................
Welcome to the forum AJ.
I don't man, these are older bikes and if she was sitting for some time it may have just rotted. I wouldn't worry much about any other o-rings or seals quite yet. No use worrying about things and loosing sleep for nothing.
Personally, I'd get some road time on her before a big trip. Lets you know how she's doing and toughens the back side. It's those new off the showroom floor vehicles that I worry about. You never know about them.
hmm
08-28-2013 07:21 AM
