Alternator fault ?
Alternator fault ?
Hi first of hello I am what you will call a newbie just registered and this is my first post.
I have a problem with my 1992 cbr 1000f she rides well until I either go a little bit faster than I should ( sorry officer ) lol or it is windy in other words when I have to accelerate more than usual, then she blows the main fuse. I have got by with it but really think I should fix this problem. My mate says I could be the alternator, just looking for conformation if there is anybody out there that can help it would be appreciated.
Thank you H.
Thank you H.
(1) shorting out under the throttle pod. seams like a good twist shorts things out.
(2) voltage at the battery at idle and voltage when rev'ed. could be the R/R sending to many amps.
I think "da boys" have it spot on !
Overcharging is generally a sign of a reg/rec on the way out, or low water level in the battery due to it being "cooked off" from overcharging.
Check your reg/rec wiring under the left side pod - rear - look for scorched wiring or a melted plug......................
Happens to all of us at some point.
Welcome to the asylum !
hmm
08-28-2013 07:21 AM
